GPIO DDRIO IP output swapped: datainhi/datainlo inverts forwarded clock
- 5 years ago
Hello Paul,
We have checked the design. We think it may be because of your coding design. We switched your 10 to 01 and got this result. Is this what you are expecting?
Image 1: Waveform
Image 2: Design
Image 3: Reference from https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altera_gpio.pdf
Thank you.
Hello Paul,
Image 1: Waveform
Image 2: Design
Thank you.
Amin,
Thank you for looking into this issue! That is exactly where I ended up: I swapped the din values as you did. I see the waveform you posted from the documentation, but that is for half-rate conversion. We are not doing half-rate conversion in this case.
My issue is that the behavior contradicts the documentation:
In this case, datain_width is 1. So
datain_h = din[(2 * 1 - 1):1] = din[1:1] and
datain_l = din[(1 - 1):0] = din[0:0]
which matches what I see in the technology mapped netlist (see my initial post in this issue). The comment at the end of the document states:
which is what I expect to happen, however swapping values in din is required to get the expected behavior.
Paul
- AminT_Intel5 years ago
The last screenshot you've given is on Guideline: Swap datain_h and datain_l Ports in Migrated IP which is for migration for your GPIO IP from previous devices to the GPIO IP core. This only applies only for the migration.
- pnp5 years ago
Amin,
I am grateful for your assistance in resolving this issue: all of our cyclone10gx_ddio_out instances are working properly now in our FPGA design. I accept that I have misunderstood the documentation and that the GPIO IP is working as Altera designed. I'd suggest, though, that it would be helpful if someone added a full-rate scenario timing diagram to the docs, because the IP does behave differently than the legacy altddio_out megafunction with nearly identical port names. At the very least, this thread will be here if anyone else is snagged.
Paul
Hello Paul,
I'm glad that it helps! Thank you for the suggestion we will take note of that.
