Patrik78
3 years agoFIR II Coefficient Reload Problems
Hello, I am using Quartus version 18.1 and I have a FIR filter in a Nios II QSYS system (created with FIR II). the filter works as expected with the preconfigured coefficients in QSYS. The issue ...
Kshitij_Intel
3 years agoHi,
Are you following the same timing diagram(as mentioned in the link below) as per your mode?
Thank you
Kshitij Goel
Patrik78
3 years agoHi,
actually the system is composed by Platform Designer, and all the read accesses are made by a Nios II processor.
The read access is simply done by a predefined IORD(), as per all the other MM slave in the system that works correctly.
So I expect this IORD follow the correct timing diagram.
Unlucky reading the one coefficient at first address deadlocks the processor that stop works. Otherwise everything works correctly.
Any ideas?
