ethernet_100g_loopback_off
I have kept some puts statements in the tcl scripts as you have suggested but for both loopback on and loopback off the rx clk=0 Hz, recover clk=0 Hz, lock status =0 and still it is showing both rx and tx mac stats.
Iam sharing the tcl scripts and also I am attaching the screenshot of the system console window for both loopback on and loopback off.
Weird, Rx clock it not on even when loop is on? Are you able to use toolkit to check the Rx CDR when loopback is on?
- Vamsi_212 years ago
I have taken a signal tap file and added recover clk, reconfig clk to it.I set the clock as clk_ref = 644.53125 MHZ
It was showing recover clk=0 and reconfig clk was running fine.
Below iam attaching a screenshot of the signal tap window. - Vamsi_212 years ago
The transceiver toolkit is not launching after loading the design to check Rx CDR when loopback is on.
