Hi Ven Ting,
I am sorry for a bit the delay in response currently I am traveling for a conference. currently, I have limited access to the system now. Will be able to address your questions well in two days.
Just for a clarification,
Can you please attach the original PCIe DMA transfer example design (without any modification) that you mentioned and include the steps to replicate the error for me to replicate the error at my end to further investigate the issue? Please let me know if you want to send the design via email
May I know if you were asking for the design which I gives error when I add signal Tap and compile (Actually this is a design with DMA example design with FIFO and counter), --if this is the case I were using the design I shared you in google drive
or you needed the PCIe DMA transfer example design (the original design without any modification).
Thank you very much.
Sijith
