15 years agordusedw not count in my dcfifo
rdusedw not count in my dcfifo EP3C16F256C8N Quartus II 9.1 sp2 a dcfifo generated by megawizard plugin manager. rdclk: 75MHz wrclk: 40MHz this is a snipping image of a running signal...
15 years ago --- Quote Start --- possibility 1: is rdclk connected to fifo? possibility 2: you have plenty of delay. Have you looked further down in signaltap? possibility 3: you have written till fifo was full and stayed full with rdcounter rolled over to zero and stayed at zero. --- Quote End --- possibility 1: I use "...|fifo0:fifo0_inst|rdclk" as the sampling clock of signaltap, if no rdclk, no data in signaltap. possibility 2: I get 256 samples each trigger, the rdusedw never changes. possibility 3: There is a "assign avl_irq = (rdusedw >= 8'd128);" in my design, when I use avl_irq = 1 as the trigger condition, no data captured. And it never stops writting data to fifo.
