wangzz
3 months agoR_Tile PCIE
I am using Quartus 26.1 and Questa 2024.1 to simulate the PCIe IP example. The selected IP is R-Tile Avalon Streaming IP for PCI Express. The example design is generated in PIPE mode. I slightly modi...
RongY_altera
Contributor
3 months agoI modified the sim to repeatedly do read after write 100 times with increased data and saw no problem.
If you do 100 128-byte data in a batch, you need to confirm sufficient size of mem has been reserved for your test.
Rong
