13 years agoQuestions about SGDMA's IN connected to Avalon-ST Dual Clock FIFO.
If SGDMA(Stream to Memory)'s IN is connected to Avalon-ST Dual Clock FIFO's out,the there are SOP,EOP signals built in SGDMA IN port. The SOP,EOP inside SGDMA IN port is INPUT attributes,and the D...
13 years agoThank you Xiwen!
Sorry for I'm a greenhand in FPGA,I still have some questions. You mean that the SOP/EOP in the INPUT port of DC_FIFO will be sent to OUTPUT port of DC_FIFO at the same time transparently without any change? So, If DC_FIFO receeives a data with its packet size is 0x2000 for example,and SGDMA reads 512 bytes data from DC_FIFO to send to PCIe IP each time. The SGDMA just reads 512 bytes data from DC_FIFO as when the SOP of DC_FIFO is high and EOP of DC_FIFO is low,and when the reading operation is end, I mean that SGDMA have read 512 bytes data,the SGDMA can end the operation by itself,and do NOT have to wait EOP signal is HIGH? Best Regards~
