lipingx
3 years agoquestion for design example of Intel fifo IP
In this example, rom_out, wrreq_o, wrclk are using the same clock trclk.
All above are trigger by rising edge of trclk.
But the fifo write are also refer to rising edge of trclk.
So if there i...
- 3 years ago
Yes, you can shift the wrclk to 180 degree which can meet timing. There is no saying you can not do that.
Richard Tan
lipingx
3 years agoI believe so, intel IP should be correct. But can you explain a little on it?
Why not move the wrclk to shift 180 degree which may perfectly meet timing constraint?
The clock wrclk rising edge will stay in the middle of fifo_in data.
