11 years agoquestion about IP generator error ID: 277000
Hi all, I ran into a problem with the following error code: Error (277000): IP Generator Error: Connection Point 'sclr' on Simulink block 'Memory_Delay1' not found on IEntity 'alt_dspbuilder_memde...
11 years agoDid you able to run why using the default example design? did you check the DSP builder version and Matlab verion is compatible? How about the OS? I would suggest you to read the readme.txt file that located at "installation path"\quartus
