Jarbugeri
1 year agoQuestion About IP Core Licensing and Timeout
Hello, I am using the following version of Quartus Prime: Quartus Prime Version 20.1.0 Build 711 06/05/2020 SJ Lite Edition I would like to confirm how I can check whether the IP Cores I am using ...
- 1 year ago
Hello Jarbugeri,
Time limited duration will be visible in IP Evaluation Time Limit Messages. So you may refer to that. But most of our IP expired after an hour.
Pavee
paveetirrasrie_Altera
1 year agoHello Jarbugeri,
Good day to you.
If you're not seeing time_limited.sof after full compilation, then the IP isn't time limited.
Hope that answer your question.
Pavee
