JLuke3
6 years agoQuartus II Lite 19.1 Linux, Cyclone 10 LP dev kit. Nios 2 error. How do I update IP core ?
Error (292019): IP core Nios II Processor (6AF7_00A2) not supported in device family Cyclone 10 LP. Choose a new device family or upgrade your IP core to a newer version. The Intel FPGA Knowledge Dat...
Vicky1
6 years agoHi,
The provided design contains verilog HDL files generated from some Mega-wizards like PLL etc. also it contains the cpu_0.v which is encrypted. so Cyclone II & Cyclone IV E devices are compatible to this design & hence design compiled successfully, since this design is provided by Terasic & there is no update about other supported devices for this design. I would like to suggest try to use same devices & supporting Quartus versions recommended by Terasic.
Vicky
