Kiamur
2 years agoQuartus 18.1 FFT IP modelsim simulation "not bound"
I try to simulate the Quartus FFT IP core in Modelsim. I succesfully simulated the example design which I also can generate from the IP generator GUI (IP Parameter Generator). However, I was not abl...
Kiamur
2 years agoHi and thanks for looking into my problem.
I have included the .qsys file with which you can build the system (here: the IP core) in the platform designer.
If you have done that, then the msim_setup.tcl should be generated, too.
Maik
