Qsys Testbench Simulation Package Descriptor (.spd) file does not exist
I am trying to simulate Nios 2 design with a floating point unit. I was able to instantiate Nios 2 processor, read inputs from FPGA and produce outputs. Now, I am trying to run a simulation. I understand that process of simulating Nios 2 processor follows different path than hardware simulation. I have a test bench written in Verilog, see code below:
`timescale 1 ps / 1 ps
module fpu_test2_top_tb();
reg [9:0] in1, in2;
wire [9:0] out1;
reg clk;
fpu_test2_top uut(
.clk(clk), // clk.clk
.in1(in1), // in1.export
.in2(in2), // in2.export
.out1(out1) // out1.export
always
begin
clk = 1;
#10;
clk = 0;
#10;
end
initial begin
#11;
in1 = 7;
in2 = 2;
#1;
$display("output = %d", out1);
end
// always @(negedge clk)
// begin
// #1;
// $display("output = %d", out1);
// end
endmodule I can run this test bench from Quartus using ModelSim. However, I don't get output from the processor. I think I have to run Nios 2 simulation out of Eclipse by first generating simulation .elf file. I went in to BSP editor and enabled "enable_sim_optimize"
Then generated BSP package and build both bsp project and application in eclipse itself. I have simulation elf file generated now
However, when I right click on application in Eclipse Run as -> Nios II ModelSim I get following error
Does anyone know how to simulate system that involves Nios II processor? What am I doing wrong here? How can I generate *.spd file?
1 Reply
- GuaBin_N_Intel
Contributor
For NIOS similation, you can refer to this document and review those steps https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/n2sw_nii5v2gen2.pdf, 3.11. Running a Nios II System with ModelSim
