FabianL
1 year agoQsys: EMIF IP Core: usr_reset associated Clock
Hello, I am a bit confused by the Usage of the emif_usr_reset_n signal of the Intel EMIF IP Core. I have added a EMIF IP Core to our Platform Designer project. Based on the Documentation (4.1.1.14...
- 1 year ago
Hi Fabian,
The reset is coming from these:
always_ff @(posedge sync_clk_pri or negedge async_reset_n_pri) begin
if (~async_reset_n_pri) begin
reset_sync_pri_sdc_anchor <= '0;
end else begin
reset_sync_pri_sdc_anchor <= reset_sync_pri_pre_reg;
end
end
You can run simulation to check the synchronous reset behavior.
Adzim
FabianL
1 year agoThanks for the clarification
