Proper way to add/initialize RAM in FPGA project?
- 3 years ago
Yes, an IP block that instantiates the ALTSYNCRAM single port RAM module should work.
This will build an INTERNAL FPGA memory using the device block RAM.
You can initialize it with a .mif file when you instantiate the module.
If you are trying to use EXTERNAL memory (like SDRAM, or SRAM) that cannot be initialized thru this means.
Ven Ting
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
