QIAN_W_Intel
6 years agoProblems when simulate the floating point functions Intel FPGA IP
I build simulation for the floating IPs, but with modelsim simulation, the outputs are always zero. I have tried several arithmetic functions, add, sub, accumulate and divide. However, I got the ...
CheepinC_altera
6 years agoHi,
Thanks for your update. For your information, I have tested with a simple add mode IP in Q19.3Pro and it seems to be simulating correctly. I have sent the zip for your reference through email as it seems like I am unable to attach to the forum. You may run the simulation by doing the following:
1. Change directory to test\test0_tb\test0_tb\sim\mentor
2. Source msim_setup.tcl
3. Type "ld"
4. Type "do wave.do"
5. Type "run -all"
Chee Pin
- QIAN_W_Intel6 years ago
Thanks Chee pin,
However, I didn't receive your email.
Do you send to the inbox of the forum?
Qian
- CheepinC_altera6 years ago
Hi Qian, Yes, you are right. I have sent through Forum which should be inbox of the forum. Please let me know if you still do not receive the file. Thank you. Best regards, Chee Pin
