QIAN_W_Intel
6 years agoProblems when simulate the floating point functions Intel FPGA IP
I build simulation for the floating IPs, but with modelsim simulation, the outputs are always zero. I have tried several arithmetic functions, add, sub, accumulate and divide. However, I got the ...
CheepinC_altera
6 years agoHi,
Sorry for the delay. I was just back to office. As I understand it, you observe some issue with floating point IPs in Modelsim simulation. To facilitate debugging, would you mind to share with me on the following:
- What is the specific Quartus version and IP that you are using?
- Mind sharing with me the .ip file of one of the floating point IP that you are using that I can have better understanding on the configuration.
- Please share with me a simple test design or simulation example which could replicate your observation. I would like to perform issue replication to see if can spot any anomaly.
Thank you.
