11 years agoproblem with FIR IP
FIR IP filter output waveform shake up and down , Input signal contains the useful signal and the noise signals , so the frequency of the noise signal may be greater than half of the sam...
11 years agoCan you describe the signal you are sampling (its amplitude and frequency), and the ADC you are using? Sampling at 25MHz seems like too much oversampling.
