11 years agoproblem with FIR IP
FIR IP filter output waveform shake up and down , Input signal contains the useful signal and the noise signals , so the frequency of the noise signal may be greater than half of the sam...
11 years ago --- Quote Start --- So you have two single tones coming from ADC; one at 1Hz, and one at 1KHz and you want to filter off the 1Khz and pass the 1 Hz You haven't said anything about Fs of signal itself. You have chosen Fs of 1KHz first then FS of 5KHz. You can't just pick a value. Your Fs must be that of input signal and should be same as ADC Fs unless you have done downsampling which I doubt. --- Quote End --- The Fs of signal itself is 25MHZ . This example is for testing the function of the FIR IP filter , and I want to know how to make a low-pass FIR IP filter with high sampling frequency signal ? thanks a lot !!!
