MSenk1
6 years agoProblem with EMIF IP and the related clocks in the .sdc file
I have instantiated a EMIF IP in Quartus 19.4. Alle emif clock are generated as the timing analyser shows (see attachment. But when I set a false path in the .sdc file for such a clock I get the fo...
MSenk1
6 years agoThank you, I was able to solve my issue, knowing that one of the clocks is a hardened path.
