MSenk1
6 years agoProblem with EMIF IP and the related clocks in the .sdc file
I have instantiated a EMIF IP in Quartus 19.4. Alle emif clock are generated as the timing analyser shows (see attachment. But when I set a false path in the .sdc file for such a clock I get the fo...
sstrell
6 years agoAs you state, you should use asynchronous clock groups. This cuts the paths between the clock domains, through the FIFO, not the clock paths themselves:
set_clock_groups -asynchronous -group usr_clk -group <clock on other side of FIFO>
#iwork4intel
