MSenk1
6 years agoProblem with EMIF IP and the related clocks in the .sdc file
I have instantiated a EMIF IP in Quartus 19.4. Alle emif clock are generated as the timing analyser shows (see attachment. But when I set a false path in the .sdc file for such a clock I get the fo...
sstrell
6 years agoWhich Cyclone 10 are you using, GX or a different variant and are you using Quartus Standard or Pro? And what is your goal for the false path? What are you trying to do?
I'm not sure why you would want to false path a clock path, but if it's a hardened path (hence my device question), it wouldn't be able to be cut.
#iwork4intel
