Problem W/ Altera VIP Frame Buffer II
Hi Kian,
Thank you for your response, I did not see it till now. I am attempting to do these calculations, but I am a little confused on how to calculate for all 4 frame buffers. I'm assuming I would calculate for 1 of them and multiply it by 4, but while doing this I realized I forgot to mention we are sending static images as of right now. The input is a RGB gstreamer pipeline with the default smpte color bars pattern that is in a paused state so the bandwidth shouldn't be exceeded. I could understand this becoming an issue when I try to input a RGB live feed in playing state into the frame buffers, but this should not be the problem while the pipeline is in a paused state. Also, while in paused state the frame rate does not apply, so I am not sure how I would calculate for the paused frame rate.
Evan
Hi Evan,
Sorry for the delay in response, I'm trying to confirm some of the information with our expert over here before able to address your question, will get back to you early this week once he is back to office.
Kian
