problem to use F-Tile Avalon® Streaming Intel® FPGA IP for PCI Express*
You can generate a PIO example design based on Gen3 1x16 first. Then go into that generated design, modify the PCIe to Gen3 1x4, and click "Generate HDL". After this, you can do a full compilation. I see no critical issue reported in this process.
Rong
- Geats_X1 year ago
But in the design of Gen3 1x16, the PIO module only supports 256 bit or 512 bit, while the bit width of Gen3 1x4 is 128 bit. I don't know how to use it when it's 128 bit.
- RongY_altera1 year ago
Contributor
The 128/256/512 bit means the data width for user logic.
Rong
- Geats_X1 year ago
So if I use the pio example design of gen3 1x16, I need to replace pio0 and mem0 modules with my own user logic. This will result in the error I explained, won't it? What I want to know is what user logic should include or at least include, so that those errors will not occur during compilation.
