14 years agoProblem detecting PHY
Hi all, I am coding my ethernet manually without RTOS or Nichestack on the DE4. My first step was to reset the MAC. - That can be done successfully The second step was to init th...
14 years agoI have never set up signaltap but will check the state of the pins.
I used the system builder to setup the pins on the board so no idea. Thanks. p.s. Socrates, is there a guide on how to use LWIP with the TSE without an RTOS? or some kind of example? I'm a bit of a newbie so need as much help as I can. Thanks
