14 years agoProblem detecting PHY
Hi all, I am coding my ethernet manually without RTOS or Nichestack on the DE4. My first step was to reset the MAC. - That can be done successfully The second step was to init th...
14 years agoI don't know how the evaluation works from the command line. But I know that if the JTAG communication is interrupted, then the core works for a limited amount of time, usually 1-2 hours. It's probably the same when killing the programmer application.
