11 years agoproblem about FIR compiler II and file paths of coefficient document
I've just started using FIR Compiler II. I restore the coefficient (.coefficient.txt) document path in file path window.However, the coefficients of file are not appear in list of coefficients.Why?
11 years ago --- Quote Start --- I've just started using FIR Compiler II. I restore the coefficient (.coefficient.txt) document path in file path window.However, the coefficients of file are not appear in list of coefficients.Why? --- Quote End --- you should click on "Apply"
