VN0001's avatar
VN0001
7 years ago
PLL Reconfiguration IP in Arria 10 Avalon Mapping
We are using Arria 10 Soc in our design. In that PLL Reconfig IP is used to dynamically changing the PLL outclock and Phase shift. So we implemented and connected the Avalon slave bus to The HPS light weight bridge as per An 728. Automatically it generated the address map also for this, But we are not able to acess from HPS.. Kindly help this to resolve this issue. attached is the snap for your reference
  • sstrell's avatar
    sstrell
    When you say you are not able to access the IP, what's happening or not working correctly? Reads or writes of the registers failing?
    • VN0001's avatar
      VN0001
      Hello sstrell,
      We are not able to write and read to the register space of that ip. No hanging and all..
      Venkatesh babu.N
  • Rahul_S_Intel1's avatar
    Rahul_S_Intel1
    Hi , Kindly provide in details. How you are not able to access HPS.
    • VN0001's avatar
      VN0001
      Hello sree, The forum site is not available. We are not able to write and read to the register space of that ip. No hanging and all.. Thanks with regards, Venkatesh Babu.N Get Outlook for Android<https://aka.ms/ghei36>
    Rahul_S_Intel1
    Kindly provide the procedure, how you read and write in the IP, is it through system console or through image or doing any partial reconfiguration
