SherwinKim
5 years agoPLL generates an incorrect 2x clock
Hi!
I'm using 2 PLLs on Arria 10 (10AX027H4F34I3SG) to create clocks. Both reference clocks are LVDS. The 3 clocks of one PLL are normal. In addition, the 2 clocks of the another PLL output become...
SherwinKim
5 years agoHi,
It has been solved.
The reason is that the pin has external termination and has not been set before.
When the LVDS clock enters the FPGA, the P / N signal will be superimposed occasionally.
