TonyCosentino
5 years agoPin Delays for Intel Cyclone 10 GX
I need to find out if the Intel Cyclone 10 GX FPGA has a published pin delays to support DDR wiring.
sstrell
5 years agoYou can check the spec estimator to see if C10GX supports what you want/need:
TonyCosentino
5 years agoThe spec estimator simply showed the cyclone device specs but no details on the DDR3 routing requirements for the Cyclone 10CX220 device. My question is very specific - Does the Cyclone 10CX220 device have internal pin delays that need to be considered when routing DDR3 on the PCB design? Or are all of the internal timing differences for matched lengths between clocks, command, address, strobes and data internally adjusted?
Tony Cosentino
919-414-2083 cell
