nome
3 years agoPFL not use
Hello
During FPGA configuration from MAX II with parallel flash by Intel P33 series
if I don't want to use PFL IP on CPLD. I am using my own HDL codes for fpga configuration
start pages de...
NurAiman_M_Intel
3 years agoHi,
The option bit is meant for the PFL IP. If you used your own codes, when generate from .sof to .pof, Quartus will generate the bit for you. Can you clarify why need to know the option bits?
Aiman
