13 years agoPCIe transceiver offset cancelation
Device - Stratix IV Using PCIe x4 Gen2. For the purpose of Transceiver offset cancelation I am using the external alt_gx_reconfig. I have been using a PLL output to feed this clock and using th...
13 years ago --- Quote Start --- For the purpose of Transceiver offset cancelation I am using the external alt_gx_reconfig. I have been using a PLL output to feed this clock and using the pll_locked as the reset generator. Like this, altgx_reconfig altgx_0_reconfig ( .offset_cancellation_reset(~pll_locked), // pll locked .reconfig_clk (pll_clk_50), // clock from PLL .reconfig_fromgxb (reconfig_0_fromgxb), .busy (busy), .reconfig_togxb (reconfig_togxb) ); This works perfectly. --- Quote End --- But it is wrong. You should not control the reset signal with a signal that is not deglitched, eg., see Altera's KB example http://www.altera.com/support/kdb/solutions/rd12172009_309.html and the SignalTap II traces in the PDF associated with this thread: http://www.alteraforum.com/forum/showthread.php?t=35678 --- Quote Start --- But I need to free up this PLL and use for another purpose and I am thinking of using a clock coming directly from the pin. And I am not quite sure what to do with the reset --- Quote End --- You could tie it to an on-board power-on reset source. --- Quote Start --- Now I am thinking the pcie reset could be connected to the altgx_reconfig. Like this, altgx_reconfig altgx_0_reconfig ( .offset_cancellation_reset (~pcie_rstn), // PCIe reset .reconfig_clk (clkin_50), // clock coming from a x'tal .reconfig_fromgxb (reconfig_0_fromgxb), .busy (busy), .reconfig_togxb (reconfig_togxb) ); But that did not work either. PCI express is not responding. --- Quote End --- That is because the PCIe core needs to start link training as soon as reset deasserts, eg., see p5 of this doc for the requirements. http://www.ovro.caltech.edu/~dwh/wbsddc/ts4_power.pdf You need to tie the reset to something that deasserts once the FPGA is configured, eg., a reset supervisor input, or an internally generated signal that asserts and then deasserts at power-on. Cheers, Dave
