14 years agoPCIe transactions between two FPGAs through switch.
hi, i work on the communication between two fpgas cyclone iv gx via idt pcie switch. i already configured the switch in such a way to route packets from fpga1 to fpga2 respecting any address ran...
14 years agoYou’re much too vague in what you need and expect from us. If you start from the PCIe MegaWizard configuration, you will have to write your own PCIe TLPs. There is nothing wrong with doing so, but it requires deep knowledge of PCI and PCIe, and I’d suggest to get hold of the respective official specifications. You will learn about PCI device enumeration, addressing modes, when and how to issue DMA transfers, the magic behind completions you receive and those you send, correctly terminating invalid or unexpected requests, handling interrupts the way you want, and last but not least, writing a correct driver for it.
Long story short: We can only guide you through this process, but we cannot give you all the ready-made FPGA and driver code. – Matthias
