sambkr
3 years agoPCie SRNS, separate perstn
Dear Support, I plan to use a PCie switch board to connect a x16 pcie lane inside a PC to 4 FPGA (4 lanes pcie) cyclone 10 GX boards. FPGA boards will be endpoints. The Pcie switch board use mini...
Wincent_Altera
3 years agoHi,
Are you using any design example provided in the IP catalog ?
Or that is a custom design ?
If you are using AVST design, you may refer to
it got explain about the reset signal.
If you would like to use the hard reset pin, I would say the nCONFIG pin is the most accurate pin for you. It is a dedicated configuration control input pin where pulling this pin low during user mode causes the FPGA to lose its configuration data, enter a reset state, and tri-state all I/O pins. Returning this pin to a logic high level initiates reconfiguration.
Wincent_Intel
