agula
5 years agoPCIe SRIOV VF capabilities
When using virtual functions on the Arria 10 device , I notice that the virtual functions do not have the same maximum read size and maximum payload size as the physical function. Is there a wa...
Deshi_Intel
5 years agoHI,
I don't have any other suggestion for you except following.
I forgot to ask you whether you changed the value in address 0x078 of PF or VF.
- I assume is VF ?
Device control register should be RW register and not RO register. Only device capability register is RO.
- Unless the VF register value is carry forward from PF and can't be edited directly
- Can you try to change the PF 0x078 to see if it bring any changes to VF ?
- If it still doesn't work then likely this is capability limit of VF
dlim
Deshi_Intel
5 years agoHI,
After some digging, I managed to find out about PCIe SRIOV spec as per attached pic
