PPham3's avatar
PPham3
7 years ago
PCIe SRIOV Avalon Stream Gen 3 automatically generate locked read request
Hi all,
I have a problem with PCIe SRIOV avalon stream. I used SRIOV example design but tried to take the tx stream and rx stream out of the APP function. When I get those signal to signaltap. I noticed that some unwanted packet just streaming down through rx stream though the sw did not write or read anything. The packet format look like a locked read request( 8 lsb bits are 0x01h). Is this issue happens to anyone? How to get it work? Thanks.
  • You need APPS in order to make your design fully function. Without the APPS, the Host should still detect end points, and I don't aware any specify signal need to be connected.
    Regards -SK ​
  • PPham3's avatar
    PPham3
    Okay, thank you. It seems that I need to make it out on my own.
