PCIe P-Tile Flow Control
- 1 year ago
Hi Anat,
On P-tile IP, there is no handling required by user application when credit is consumed due to internally generated TLP. Just that the credit return to user is slower.
This means that HIP decrements new FC_update credits values before to pass them to the user application as TX credit limit when HIP has consumed internal credits.
In that sense user application will have less credits that once sent by PCIe link partner agent in FC_update DLLP.
For example, the RP send FC_update PD=20 and HIP had consumed 4 credits then user application will received PD=16 (TX credit limit signal) where previous TX credit limit value was PD=16 or less.
Does this acceptably answer your question?
Wincent
Hi Wincent - Thank you.
Could you clarify on the RX side FC as well,
"4.In the case of RX flow control, instead of the number of credits, flow control is defined in terms of Number of TLPs. Any examples for this conversion while calculating available credits?"
- Wincent_Altera1 year ago
in Rx flow control, perhaps you can check on
https://www.intel.com/content/www/us/en/docs/programmable/683059/24-3/rx-flow-control-interface.html
Let me know if there is anything in the user guide that is not clear for you, or I am not answering your question accurately.
Wincent_Altera
