Karthik30
1 year agoPCIe P-Tile avalon RX header address insights
Hi in the P-Tile Avalon in the RX part only lower 6 bits of address is use. 1. Is it a byte address or dword address. 2. If an byte address then how only 6 bits can take byte address greater then 12...
Wincent_Altera
1 year agoHi,
>> sorry i do not get your question, may I know what is the current gen speed that you are running ?
>> where you get the 6 bits address that you acquired from ? is there mentioned in the user guide ? appreciate you can redirect, just to ensure we are looking at the same picture.
>> may i know specific which rx header that you are looking at ?
If you are referring to the header width, you may check below
https://www.intel.com/content/www/us/en/docs/programmable/683059/24-3/overview-56727.html
Wincent_Altera
