14 years agoPCIE link -up status
Hi , I am migrating an old design i had using a soft PCIE core to cyclone 4's hard IP. I had a 'link-up' status signal which I used to drive an LED whenever the link became active. Is there an equiva...
14 years agoThe link is consider up when the 10G MAC successfully transmit or receive idle to/from the link partner. Use the 10g MAC "link_fault_status_xgmii_rx" output.
1) link_idle = 2b'00 <- after powerup, this show link idle because the system is still in reset stage. 2) link_training = 2b'01 <- after transceiver reset sequence is complete, the link is still not stable and trying to transmit the idle here. 3) link_up = 2'b00 <- the link is stable and successfully transmit/receive idle, the mac will show link up.
