PCIe IP generate support
- 5 years ago
HI Moti,
I presume you are using PCIe Gen 1 preset in NativePHY IP.
By default, it will be 10 bits with 125MHz.
You can disable the Tx serializer and Rx de-serializer setting then it will become 8 bits with 250MHz.
Refer to the attached pic in my previous post.
dlim
HI Moti,
dlim
Hi dlim,
Further to the question on the page
Table 99. PIPE Gen3 32 bit PCS Clock Rates p.172
that I can choose, gen 1 will work with clock of 62.5MHz , How can I choose this clock rate and use it for pipe clk ?
Moti
