PCIe IP generate support
- 5 years ago
HI Moti,
I presume you are using PCIe Gen 1 preset in NativePHY IP.
By default, it will be 10 bits with 125MHz.
You can disable the Tx serializer and Rx de-serializer setting then it will become 8 bits with 250MHz.
Refer to the attached pic in my previous post.
dlim
HI Moti,
dlim
- Moti5 years ago
Hi dlim,
Further to the question on the page
Table 99. PIPE Gen3 32 bit PCS Clock Rates p.172
that I can choose, gen 1 will work with clock of 62.5MHz , How can I choose this clock rate and use it for pipe clk ?
Moti
