PCIe IP generate support
- 5 years ago
HI Moti,
I presume you are using PCIe Gen 1 preset in NativePHY IP.
By default, it will be 10 bits with 125MHz.
You can disable the Tx serializer and Rx de-serializer setting then it will become 8 bits with 250MHz.
Refer to the attached pic in my previous post.
dlim
I do want to use the NativePhy IP with the PCIe PIPE interface, and for that I need in Gen 1 that work at clock rate of 250MHz with 8bits data.
at the Data sheet that you referred to at Table 103 I can see that this IP support 125MHz with 16bits or 250MHz with 8bits (that what I need)
But I did not find at the Mega Wizard any option that can I control this, also when I implement that IP I received data of 16bits at 125MHz.
So how can I change/control that to be 250MHz with 8bits ?
Refer to the steps in attached pic
