PCIe IP generate support
- 5 years ago
HI Moti,
I presume you are using PCIe Gen 1 preset in NativePHY IP.
By default, it will be 10 bits with 125MHz.
You can disable the Tx serializer and Rx de-serializer setting then it will become 8 bits with 250MHz.
Refer to the attached pic in my previous post.
dlim
HI Moti,
We have few PCIe IP solution.
Can you help to clarify which IP and which datasheet doc that you are referring to ?
- First of all, can you let me know which datasheet doc that you are looking at that clarify support for PCIe Gen 1 with 250MHz ? Can you share with me the doc link and its chapter section/page number ?
- After that, pls clarify which FPGA IP that you initiated to generate PCIe ? Let me know the exact FPGA IP name. For instance, NativePHY IP or some Avalon MM/ST PCIe or DMA IP and etc...
dlim
- Moti5 years ago
Thanks for the quick response,
link for the data sheet that I found ( page 47 ) : https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pci_express.pdf
the IP that I choose is L-Tile/H-Tile transceiver Native PHY Intel Stratix 10 FPGA IP, if there is other IP that I can Use for these needs please let me know.
Moti
