jmcguire3's avatar
jmcguire3
4 years ago
PCIe HIP - only one legacy INTX interrupt available
I have a legacy support task - obsolete hardware, critical system, etc - where I need to emulate some old, obsolete, unobtanium peripheral components in an FPGA. The peripherals in the system use th...
  • Wincent_Altera's avatar
    Wincent_Altera
    4 years ago
    Apologize for late, hope this helpful.
    There is two AVMM example available in the Quartus, one is AVMM another one is AVMM+
    • For the AVMM example design indeed you will get "1"
    The document provided by you early 3.2.3.3.1. Interrupt Signals Available when the PCIe Hard IP is an... (intel.com)
    Shows that the 4bits intx_req_i is only available for AVMM+
    I try to run the example design (AVMM+) and I get the result below
    Let me know if this is helpful, please correct me if i am wrong.
    Wincent_C
