14 years agoPCIe hard IP in Qsys bar0 or bar1_0?
Which is the bar used for PCIe hard IP in Qsys? Why all the documents says bar0, while the Qsys diagram shows "bar1_0"? Is "bar1_0" equal to bar0, or is it bar1? Thank you very much!
14 years ago --- Quote Start --- Which is the bar used for PCIe hard IP in Qsys? --- Quote End --- Whatever BARs you set up. --- Quote Start --- Why all the documents says bar0, while the Qsys diagram shows "bar1_0"? Is "bar1_0" equal to bar0, or is it bar1? Thank you very much! --- Quote End --- When BAR0 is defined as 64-bit, BAR1 gets 'used up', so bar1_0 really just means a 64-bit BAR0. Cheers, Dave
