Moti
5 years agoPCIe Gen3 PHY-IP
I use Stratix10, quartus pro 20.3, I want to generate IP PHY of PCIe, NativePHY IP with PCIe PIPE mode only.
I saw at https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/str...
SengKok_L_Intel
5 years agoHi,
You will not see the 62.5Mhz for selecting the Gen1 capability only. This is because gen1 is not using 32 bits interface. This 62.5Mhz is referring to when you select Gen3 Capability mode, but it down trained to Gen1.
Regards -SK
- Moti5 years ago
Hi
thanks for the response,
yes, I choose gen3, but the PCS clk is 125MHz . ( as the img I attached )
In these default values gen1 will work at 62.5MHz ?
