14 years agoPCIe Control Register Access - QSYS - Nios
I'm using Qsys in order to interface my Nios application to an external microprocessor via PCIe Interface.
After Nios do some operations I need to generate a IRQ toward PCIe in order to advice the external processor that data are ready, etc. In order to do that in my Qsys system I've interconnected Nios_Data_bus with PCIE control register access and also the Nios Interrupt Sender to PCIE CRA Receiver. I've 2 different problems in Nios II environment (consider that I'm quite new in software writing, so maybe some are mistakes). 1- First I expected in NIOS system.h some# define register to access to PCIe IRQ Enable and IRQ Status, whereas I found only: # define __ALTERA_PCIE_HARD_IP and also /* * PCIe configuration * */ # define ALT_MODULE_CLASS_PCIe altera_pcie_hard_ip # define PCIE_BASE 0x8000 # define PCIE_IRQ 4 # define PCIE_IRQ_INTERRUPT_CONTROLLER_ID 0 # define PCIE_NAME "/dev/PCIe" # define PCIE_SPAN 16384 # define PCIE_TYPE "altera_pcie_hard_ip" In reality PCIE_BASE is exactly the mapping of PCIe CRA in my NIOS memory, so that's ok. Other than that I've no clue on how use these informations.. In order to generate a IRQ toward PCIe, I've understand that I've to enable interrupt RXm_IRQ writing at CRA_BASE_ADD + 0x50 and that then I'll set the interested IRQ writing at CRA_BASE_ADD + 0x50. Is that all right? I think that it is very strange that in System.h I do not have any reference to the CRA internal registers as with all others perypheral I've used. 2- To overcome to this "problem" I've generate an external file .c # define AVALON_MM_TO_PCIE_IRQ_ENABLE (0x50U) # define AVALON_MM_TO_PCIE_IRQ_STATUS (0x40U) void pcie_irq_ena(alt_u32 pcie_csr_base_addr, alt_u16 irq_mask) { IOWR_32DIRECT(pcie_csr_base_addr, AVALON_MM_TO_PCIE_IRQ_ENABLE, irq_mask); } /* GENERATE THE IRQ */ void pcie_irq_gen(alt_u32 pcie_csr_base_addr, alt_u16 irq_mask) { IOWR_32DIRECT(pcie_csr_base_addr, AVALON_MM_TO_PCIE_IRQ_STATUS, irq_mask); } /* RESET IRQ */ void pcie_irq_clear(alt_u32 pcie_csr_base_addr, alt_u16 irq_mask) { IOWR_32DIRECT(pcie_csr_base_addr, AVALON_MM_TO_PCIE_IRQ_STATUS, ~irq_mask); } I think that I've missed something..
