Muneet
1 year agoPCIe AXI Streaming IP Packet Header Slot Number Details
Is the Slot Number information provided in the PCIe header (AXI Streaming IP, Document ID: 790711) the same as the Physical Slot Number of Slot Capabilities Register [31:19] defined in the PCIe Base ...
Muneet
1 year agoHi Wincent,
Thanks for your response.
How will the mapping of these end-points based on slot number be done? Is it handled by the main system in the Hierarchy (Root Port) or by the user through user-defined interfaces?
Wincent_Altera
1 year agoHi Muneet,
For example if you are using D-state you write the slot number accordingly to the bit
https://www.intel.com/content/www/us/en/docs/programmable/790711/24-3-1/d-state-sts.html
You may refer other register name in section 7 as well.
Wincent
