PCIe Arria 10 HIP MSI-X
I'm wondering if I could receive any guidance or documentation for MSI-X interrupt generation. For example, could I receive more clarification on the Vector Control field defined in the MSI-X table? What does the concept of masking refer to and how do I detect if it is masked? Additionally, how do I pass a message to the interrupt service routine of the host SW? There is a message field in the MSI-X table, can I put the message I want the software to receive when servicing the ISR? If not, what is the standard way for doing this?
Thank you!
- SengKok_L_Intel
You may refer to the following link, section 8.1.3 (or page 115) for some of the detailed info regarding the implement MSI-X interrupts.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_a10_pcie_avst.pdf
Regards -SK
- agula
Thank you for sharing this. Based on this section, it seems the only way to send data to the software is by creating a separate memory write to a DMA region in the software driver. Is this the case?
- SengKok_L_Intel
Yes, software needs to setup the MSI-X table via any of the BAR at the application layer.
Regards -SK
- SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
- agula
When trying to use MSI-X interrupts on a virtual function, the host crashes. The host crashes when trying to use request_irq(). When using MSI-X interrupts in virtual functions can you use any BAR entry for the MSI-X table ? Does this memory region also need to be readable by the host machine or only write able ? Setting up the MSI-X table from the host PC doesn't seem to be an issue with the physical function. The user guide for this says multi-function variants can only access MSI-X table from BAR 4. Although, I am not sure if this is a mistake because the mega function wizard does not restrict me from setting the BAR to 0.
Thank you
