danield17
1 year agoPCIe and Scaler II IPs
Hi, I’m working on a project that transfers an image via PCIe to a Scaler II IP, processes it, and then sends it back to the host computer. My initial plan was to connect the PCIe IP to two mSGDMA ...
VenT_Altera
1 year agoHi Danield,
Thanks for reaching out.
Allow me some time to investigate your issue. I shall come back to you with the findings.
As you are using Agilex 7 I-Series, are you using F-Tile or R-Tile? Do you need to use the MCDMA IP, or can you switch to the F/R-Tile AVST IP?
Ven
- danield171 year ago
Hi Ven,
I’ve already found a solution.
To answer your questions:
- I’m using the R-Tile.
- I didn’t specifically need the MCDMA. my goal was to find a solution that works regardless of the device or PCIe IP being used.
- I preferred sticking with a PCIe IP that supports a memory-mapped interface, as I find it more flexible and convenient.
The solution I settled on was transferring the image to an EMIF and connecting two Frame Buffer II IPs to it. one configured as a Frame Reader to send the image to the video IPs, and the other as a Frame Writer to return the processed image from the video IPs back to the EMIF.
Daniel
